Changing fuel pump
Old Sep 22, 2007 | 2:09 PM
Roy's Avatar
Roy
Default Changing fuel pump
I have a '97 1500 Suburban that I need to change the fuel pump on. I have the gas tank on the ground. What is the secret to getting the unit out of the tank? I don't see any screws/bolts to take off.
Old Sep 22, 2007 | 4:05 PM
RonH's Avatar
Default RE: Changing fuel pump
It's a ring that fits around the edge of the fuel pump unit that unscrews.
Old Sep 22, 2007 | 4:27 PM
McGuireV10's Avatar
Yeah, a flat metal lock-ring with three flanges rotates and slides out of the other metal piece permanently attached to the tank. I've changed the sender and/or fuel pumps on a few GM vehicles and frankly I've never been able to get the ring off without needing to replace it, so you might want to go ahead and order another one now -- they're cheap. Also order the O-ring that goes under the metal flange.
I use rockauto.com for simple non-performance parts like this, they're fast and cheap. Drill-down to your vehicle, look under "Fuel/Air" then under "Fuel Pump Tank Seal". For my wife's Camaro (which I did just a few weeks ago) the lock-ring and O-ring came to about $8 with shipping. Should be more or less the same for your truck.
Old Sep 22, 2007 | 6:05 PM
Roy's Avatar
Roy
Thanks for the info.
BRB
Dec 28, 2012 8:34 PM
aboyaser
Nov 20, 2012 9:04 AM
hunter10220
May 18, 2011 8:37 PM
skibumm
Feb 13, 2009 10:44 AM
sleet
Oct 11, 2006 11:36 AM
