Changing rear axle
Old May 18, 2023 | 4:56 AM
cujotiger69's Avatar
Default Changing rear axle
I have 13 suburban with 3.08 the rear end is bad i have acess to another rear end except the geat ratio is 3.42 if i swap them out will work?
Old May 18, 2023 | 8:38 PM
oilcanhenry's Avatar
Yes, unless for have a 4x4. You have to have the same gear ratio's on both front and rear axles in that case. The 3.42 is a good gear ratio, as close as you can get to a 3.55 which I like the best. 3.73 is what my 98' K-1500 has.
Old May 23, 2023 | 12:56 AM
Its a 4×2 so thank u
Old May 23, 2023 | 3:02 AM
your speedometer + odometer will be off. Transmission won't shift right, and ABS won't work right either. Unless you get your ECM, TCM and EBCM reprogrammed, which is a pretty big deal. The dealership won't do it. I suggest sticking to the same axle ratio to make life easier.
wolffullmoon
Mar 22, 2023 9:10 PM
10ga
Jun 2, 2021 2:46 AM
Swiss-Suburban-07
Apr 11, 2020 2:51 AM
CMOS
Nov 1, 2008 10:38 AM
papak
Colorado
Jun 24, 2008 6:42 PM
