4wd Issue
Old May 20, 2023 | 7:47 AM
xrsurfguy's Avatar
Default 4wd Issue
I have a early model 1999 (older body style) Tahoe. I'm having issues with the 4wd. The light on the selector switch says it's in 4wd but the it isn't. It also won't let me select 2wd, 4low etc. Its a new 4wd selector switch, tried the old one which still works and that didn't change anything. Tried a new 4wd actuator and that didn't fix anything. Fuses are all good, grounds too. The only thing that seemed to fix it was I disconnected the battery for and hour and it reset everything. The problem was the next day it was doing the same thing again. There is a CEL on so I"m getting a code reader today to check it.
Any other things I should look at? Relays?
Thanks for any help
Old May 24, 2023 | 3:27 AM
oilcanhenry's Avatar
Thanks for any help
Could be a bad actuator on the transfer case. A code reader might pick that up.
Dawg77
1988 - 1998 (GMT400)
Jan 11, 2024 8:25 PM
Pawpawh2000
Jan 15, 2022 3:52 PM
fsxbob
12
Jul 21, 2021 10:44 PM
dstark
Apr 10, 2015 8:05 PM
Rmatt34
Dec 29, 2012 7:25 PM
