Old Jul 29, 2015, 12:15 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Powertrain Guides
Print Wikipost
Changing Spark Plug On Cylinder 8
Old Aug 16, 2021 | 11:48 PM
  #21
emptech's Avatar
Originally Posted by bird
I used a 1-inch 3/8" extension with the Spark plug socket and a normal 3/8" Ratchet for the #8 Plug. Laid across the engine and pieced the 3 together because you can't just snake it in there.
1. Put socket on plug(mostly by feel, you can't see it)
2. add 1-inch extension to socket.
3. slide ratchet in and remove.
I didn't try a swivel, was too afraid to tweak something.
I had a harder time getting the boot off the plug itself. No room to gain torque with your hands. Twist it off worked best.
What a pain in the butt, I was able to use a 5/8 plug socket with a 1" extension like you said, worked like a charm, yes, lost a bit of blood.
To pull the boot off, I have a pair of tongs used to pull spark plug wires, it greatly helped.
I wish the armchair quarterbacks would not make suggestions unless they have already tried their suggestions.
Your's worked! Jim
Old Aug 17, 2021 | 8:11 PM
  #22
Cusser's Avatar
Great suggestion !
Old Aug 18, 2021 | 8:57 AM
  #23
repairman54's Avatar
Changing plugs on these trucks is a piece of cake.
Try changing plugs on a transverse V6 that the intake manifold has to be removed.
Old Aug 18, 2021 | 9:16 AM
  #24
Cusser's Avatar
When my daughter's '98 Pathfinder needed new plugs, I read on the Nissan boards how tough the #6 plug was to change. Quite a few folks just changed out the 5 easier to access plugs. Some removed the hood. Anyway, I used a mirror, 2 short extensions, had to use my left hand to seat the socket onto the plug. Took me about 45 minutes, laying across the engine on a towel.
Stirgen
Mar 28, 2022 9:09 PM
mamulan
Aug 20, 2014 8:39 AM
arodgers91
Apr 18, 2014 1:02 AM
TPM
May 14, 2013 5:58 PM
aboyaser
Nov 20, 2012 9:04 AM
