check engine code P0430
Old Jul 7, 2012 | 12:31 PM
firemechanic's Avatar
Default check engine code P0430
my SES light came on and checked the codes and came up with p0430 which i know is the catalytic convertor bank 2. I have a couple question maybe someone can answer. The code is always active even when the ignition is on and engine off code it possibly be the sensor. Also it seems that the p0430 code is more common than the code for bank one why is that or is it just me
Old Jul 7, 2012 | 1:06 PM
kevinkpk's Avatar
once it is set, it stays till you clear it.
Old Jul 7, 2012 | 8:48 PM
MDTAHOE's Avatar
Professional Mechanic
You need the cat. You can throw as many sensors at it as you want but the cat is the fix. Also only use a dealer part 75% of the aftermarket ones fail in the first 6 month and you have a cat code again. This is even more critical on California, NLEV or ULEV cars and trucks. We stopped using aftermarket cats on OBDII vehicles at works do to to many come backs.
skyboy2410
Aug 18, 2012 10:54 AM
dhoff024
Jul 10, 2012 9:16 PM
RachelJWalker
May 16, 2012 8:27 AM
rkrueger
Dec 31, 2011 5:38 PM
Copedawg
Feb 2, 2011 3:50 AM
