Check engine light
Old Oct 2, 2006 | 12:37 AM
miketieman's Avatar
Default Check engine light
I have a 95 Suburban that has a strange engine light problem. The check engine light will come on, it does not blink, just stays on. Normally the check engine light does not come on until I drive the suburban for awhile. When this happens the transmission starts to shift rough, if I turn the truck off and then restart, the check engine light will turn off and everything is fine for awhile and then might happen again. Sometimes I can go 2 weeks and it will never act up, then there are times that it will act up everytime I get in the truck. Any suggestions?
Old Oct 4, 2006 | 6:16 PM
ZX1100F1's Avatar
Default RE: Check engine light
There is a problem with a parameter (signal out of bounds) of the ECM, have a shop with the proper equipment chack the system and replace the faulty component.
redrotor
Cobalt
Aug 29, 2019 8:38 PM
o.valdez
Dec 17, 2011 10:46 PM
psd7.3
Dec 22, 2010 8:23 PM
101btp
Nov 30, 2010 8:36 PM
93chevyman
Mar 12, 2010 1:13 PM
