chevy tahoe 2007 overheading
hi is it normal for the temperature to go over 210, I have a Tahoe 2007 and when is on traffic the temperature goes close to 3/4 for a min or two and it goes down to 210 again, we change the thermostat and the radiator?
You can also get an infrared thermometer and check the temp at the thermostat housing. If you are relying on the dash gauge, you will find they are not always accurate.
My temp needle doesn’t budge once it’s at operating temp of 210 F. See what your cooling fan is doing. Also, is the temp increase identical before and after the thermostat change?
Does your model have an electric cooling fan? If so, is the fan cycling or on full blast.
SD
SD
And are ALL your fan shrouds in place?
mm9399
February 16th, 2017 2:50 AM
