chevy tahoe 2007 overheading
Old Nov 15, 2017 | 10:18 AM
epa87's Avatar
Newly Registered
Default chevy tahoe 2007 overheading
hi is it normal for the temperature to go over 210, I have a Tahoe 2007 and when is on traffic the temperature goes close to 3/4 for a min or two and it goes down to 210 again, we change the thermostat and the radiator?
Old Nov 16, 2017 | 9:21 AM
Check the temperature sensor if it is still doing it.
Old Nov 16, 2017 | 12:13 PM
SBchevyfan's Avatar
You can also get an infrared thermometer and check the temp at the thermostat housing. If you are relying on the dash gauge, you will find they are not always accurate.
Old Nov 19, 2017 | 11:06 AM
Suburban Dude's Avatar
My temp needle doesn’t budge once it’s at operating temp of 210 F. See what your cooling fan is doing. Also, is the temp increase identical before and after the thermostat change?
Does your model have an electric cooling fan? If so, is the fan cycling or on full blast.
SD
Old Feb 8, 2021 | 8:56 PM
Claribel Rodriguez's Avatar
My truck is heating up after WE changed the Water Pump and the Thermostat and it still heats up to 210 and 3/4 is that normal. ???
Old Feb 9, 2021 | 8:39 AM
Cusser's Avatar
SD
And if belt-driven fan, I'd replace the fan clutch. Your symptoms of running hotter in traffic are very indicative of low air flow through the radiator.
And are ALL your fan shrouds in place?
Jay Wells
Sep 18, 2019 12:50 PM
mm9399
Feb 16, 2017 2:50 AM
iCrash
Mar 9, 2011 8:12 PM
ekoms
May 30, 2010 10:36 AM
Black 5.3
Feb 21, 2007 6:13 PM
