Clicking / Ticking from front suspension area
Old Aug 28, 2007 | 12:24 AM
copout221's Avatar
Default Clicking / Ticking from front suspension area
Here is another new problem I was hoping someone could help me with before I head off to the dealer. I am hearing a clicking / ticking sound from the front suspension areaon my 2007 LTZ with 2k miles. I can hear it when I hit small bumps with the windows down and it also clicks after parking the truck and whilegetting out. I initially thought the noise was coming from the transmission but I can physically shake/push the front tires/wheels (both sides) with my hands and hear the clicking sound. Is this a normal condition or has this problem been addressed/discussed before. It makes the sound if the truck is in 2wd, auto, or 4wd so that is most likely not the problem. Thanks
Old Aug 28, 2007 | 4:17 AM
RonH's Avatar
Default RE: Clicking / Ticking from front suspension area
Maybe a valve inside one of the shocks? Maybe something plastic or a wiring bundle catching on a body or a frame part?
Does it only happen with movement of the vehicle, or does it continue to tick after all movement has stopped?
Old Aug 28, 2007 | 10:14 AM
copout221's Avatar
It only occurs when the shocks are being compressed some way. So when I hit small bumps, speed bumps, gettin in or out of the truck, etc I can hear it. I am going to run by the dealer today to see if they can take a quick look at it before making an appointment.
Old Aug 28, 2007 | 10:36 AM
ZX1100F1's Avatar
Could be the front brake pads rattling around on the calipers.
Try lightly depressing the brake pedal when you notice the noise and see if it doesn't disappear.
If this is the case I recommend replacing the brake pads and properly installing any anti-rattle clips that come with the new pads set.
Old Aug 28, 2007 | 12:48 PM
copout221's Avatar
ORIGINAL: ZX1100F1
Thanks ZX. I will give thata try. It is definitely coming from that area so maybe it will be a simple fix. Otherwise I have an appointment next week for this noise, the navigation radio clock issue, and my change cover is warped or something since it doesn't sit flush with the console.
Old Sep 16, 2007 | 5:05 PM
ffsamuel's Avatar
I have the same problem on a 2004, can youlet me in knowwhat you found out about the problem, I tried lubing the front bushings on everything with no results. Thanks
beasticles
Apr 7, 2018 4:58 PM
baddad61
Nov 3, 2011 4:55 PM
04SSC302
Sep 26, 2010 3:40 AM
litcatp
Jun 4, 2009 1:44 PM
HulaGirl
Avalanche
Nov 28, 2007 8:26 PM
