Code b3770 mode door actuator
Old Dec 20, 2020 | 6:27 AM
s281er238's Avatar
Default Code b3770 mode door actuator
Hey guys I had a code b3770 mode door actuator that was bad I replaced it with with a ac delco and it still don’t work. I can manually move the actuator with a power probe but it won’t with the command sent from
control head. I even replaced the control head unit
still no response. I delete the code with my computer scanner and it still won’t go away it keeps coming back. I check the movement with the scanner and it won’t show any reading from command all the reading are 0 which is odd for the mode door . I have proper voltage readings and power going to the harness wire that’s connected to the actuator but still no luck. Any ideas
s281er238
Dec 12, 2020 8:36 AM
willyg1997
Jul 11, 2018 2:35 PM
Manikmekanic
Nov 20, 2017 3:30 PM
EpicFruit
Jul 25, 2012 4:18 PM
greg72757
Oct 28, 2009 10:23 PM
