Coolant leak 2001 suburban
Old Dec 18, 2015 | 7:06 PM
rlbaldwin25's Avatar
Default Coolant leak 2001 suburban
My 01 suburban LT 5.3L leaks roughly about a half gallon of coolant everyweek. After I top it off the low coolant light will typically come on within 20 minutes of driving. I have searched all over the engine compartment and found a small wet spot on the water pump and a few drops on cables on the bottom of the engine but cannot track that back to a source. I'm debating changing the water pump to see if that helps but have read other forums that say the engine is just bad and may need replaced. I was wondering if anyone had any advice on what this may be. I looked under the oil cap to see if any coolant had condensate there and it looked like there was some dex-cool condensation under there but it seems like the amount of coolant I go through is too high compared to other people that were having issues with their coolant leaking into the oil.
Old Dec 18, 2015 | 9:03 PM
cleveland63b's Avatar
waterpumps are pretty common leaks on those, check your oil level and if its milky?
Old Dec 18, 2015 | 9:36 PM
I'm changing the water pump with fingers crossed. looks like it has been done before but can't hurt. Oil looks good, level and appearance.
Old Dec 19, 2015 | 1:19 PM
loxahatchee's Avatar
you may be leaking coolant into your combustion chamber. so you won t see any evidence in your oil cap.
Old Dec 19, 2015 | 3:21 PM
you could do a combustion gas test on it but if you have a visible external leak that would be the cheaper and easier starting point
Old Dec 29, 2015 | 12:31 PM
Swapped the water pump and the light has been off for 2 days now. I assume that was it. Thanks.
