Coolant leaking from exhaust manifold
After cylinder head replacement now I have coolant coming from top of exhaust manifold between 6 and 8 cylinders until engine is warm wtf dropped Suburban off at shop for warranty but what happend ?
See the light spot on manifold with white edges ( burnt coolant)
They ****ed it up. That's what happened.
The following 2 users liked this post by mountainmanjoe:
dennishnks (April 26th, 2022),
NPoulos (March 17th, 2020)
I'd say cracked head, if the head gasket was leaking the leak would be below the exhaust manifold not above it! Going away after warm up makes me think crack too, head heats up and expands closing the crack.
@ Little Bear
Good point. Could also be intake gasket which is above exhaust manifold. Could be seeping around.
@NPoulos
why did you get top end work done?
@NPoulos
In English, we use periods to make text easier for people read. Please and thanks.
OK so it didn't overheat. I assume you mean spark plugs and not core plugs.
I would inspect the intake gasket.
Possible intake leaking
If you know anybody has a smoke machine I would try that because that will actually show you where the leak is before you go turn it down again
13
February 19th, 2008 12:13 PM
