Cracked axle tube
Old Dec 23, 2024 | 2:12 PM
CaughtInCeilingFan's Avatar
Default Cracked axle tube
Just peeked under my suburban and saw that my front axle tube is cracked, right where the tube meets the diff housing. What all is needed to repair/replace the tube? I've already looked online and found the axle tube, gasket and bearing. Of course, I'll need diff oil (75w90 synth, I'm guessing). Are there any other parts I'll need to do this? Don't even know how long it's been like this. There's no noise coming from the front end. I'd just rather fix this so it doesn't get much worse.
2001 suburban LS, 194k miles
Old Dec 23, 2024 | 2:37 PM
Try and find out why it cracked and fix the problem, so it won't happen again. Take it to a good welding shop, they might be able to repair it and save all of the work and money needed to replace it.
Old Dec 24, 2024 | 7:55 AM
Update: 4wd still seems to work. It starts to bind when in turns though. All of the nuts and bolts are still tight and appear to be lined up correctly.
Old Feb 13, 2025 | 3:47 PM
Found a replacement diff and axle tube. Don't know the condition of the one with the cracked tube. Figured this was a safer bet. I've checked the part numbers and they both come back to the same thing, 3.73 gear ratio, 99-06 suburban/Tahoe/Silverado.
Part number on the axle that's currently in it is 40012681 and has the letters "F 4" on the tube.
Scottlp123
2014 - 2018 (GMT-K2)
Jan 14, 2024 10:20 PM
nkh34
Apr 21, 2015 9:41 AM
Yogi
Mar 7, 2014 4:02 AM
grschell
Jan 30, 2010 11:50 AM
suzuki-guy
Aug 6, 2009 8:58 AM
