cranks longer than before
Old Oct 14, 2010 | 1:20 PM
Sparky Sparks's Avatar
Default cranks longer than before
Our 2005 Suburban cranks longer than before. If you tickle the peddle it starts. She has 70k miles on her & runs smooth otherwise. She's averaging 17mpg. I do add 3 ounces of Lucas fuel injector cleaner to the tank every 90 days. What could be the trouble? Could it be; plugs, throttle body dirty, clogged fuel injectors, vapor lock, all of the above...what? Where do we start? We have done zero maintenance besides oil & filter changes.
Old Oct 17, 2010 | 8:00 PM
Might try cleaning the throttle body and associated idle control.
Old Oct 17, 2010 | 9:19 PM
RacerX's Avatar
Check for codes. Tickling the pedal has nothing to do with starting. That is not a carbureted car. I d guess if you didnt touch the pedal it would start easier.
Sparky Sparks
Mar 9, 2011 9:11 AM
MichaelJAwesome
Jun 14, 2010 8:00 AM
julian734
Aug 3, 2008 8:14 PM
