Crankshaft Position Indicator
If you change the Crankshaft Position Indicator that is behind the starter on a 2002 Suburban, do you need to have the dealership perform a "learning procedure" or do you replace it and if the engine runs you are fine?
I wondering if my no spark, no fuel pressure problem is a Crankshaft Position Indicator failure. I'm suspect because I have no codes.
JBC
JBC
Last edited by in2pro; July 2nd, 2011 at 7:40 PM. Reason: Edited title for clarity of thread
flores5996
October 24th, 2010 8:54 PM
