Crankshaft Position Indicator
Old Jul 2, 2011 | 12:18 PM
JBC's Avatar
JBC
Default Crankshaft Position Indicator
If you change the Crankshaft Position Indicator that is behind the starter on a 2002 Suburban, do you need to have the dealership perform a "learning procedure" or do you replace it and if the engine runs you are fine?
I wondering if my no spark, no fuel pressure problem is a Crankshaft Position Indicator failure. I'm suspect because I have no codes.
JBC
Last edited by in2pro; Jul 2, 2011 at 7:40 PM. Reason: Edited title for clarity of thread
Old Jul 2, 2011 | 5:32 PM
JimJ's Avatar
I think you may have mentioned your problem. NO FUEL PRESSURE.
Old Jul 2, 2011 | 5:33 PM
JimJ's Avatar
Sorry didn't read No Spark.
Old Jul 2, 2011 | 7:35 PM
no programming should be needed for the crank or cam position sensors...
Make sure you check all fuses before digging too deep
Old Jul 2, 2011 | 10:37 PM
JimJ's Avatar
Did your post in another thread mean that you found and fixed your problem ? If so you should keep all your posts on one problem in the same thread.
beastro
Aug 6, 2011 3:15 PM
sum67
Dec 2, 2010 7:13 PM
flores5996
Oct 24, 2010 8:54 PM
Bob5150
Aug 22, 2010 6:45 PM
vf171
Jul 17, 2007 5:27 PM
