Creaking when turning
Old Sep 29, 2010 | 12:46 AM
ldr's Avatar
ldr
Default Creaking when turning
Hey there,
I do have a new Tahoe Z71 and today while the AC Fan was pretty low for the first time because temperatures dropped below 35C I could hear a mild metal creaking from the front suspension while turning and driving over a bumpy road.
Now I am not sure if this is something "normal" in the Tahoe or if I should see the dealer for that? Its not really making a lot of sound but you can hear some noise.
EDIT:
I just remember that once I took it offroad in the desert and I sent it flying at around 10inches. Is the suspension supposed to handle that? Are there any parameters about what a suspension should be able to handle?
Old Sep 29, 2010 | 9:58 AM
old dog's Avatar
Default creek !!!!!!!!!!!
sound's like something is dry but if it is the 20110 in your profile i would have it checked buy the dealer ,otherwise grease the ball joints and idler arm for shure .
Old Sep 29, 2010 | 9:33 PM
Only grease zerks are on the tie rod ends. All others are "sealed".
Old Sep 29, 2010 | 10:38 PM
Zed 71's Avatar
Take it in. There is a TSB for the front struts.
Old Sep 30, 2010 | 2:16 AM
ldr's Avatar
ldr
Whats TSB?
Old Sep 30, 2010 | 8:28 AM
old dog's Avatar
Default tsb
technical service bulletin .
Old Oct 3, 2010 | 4:56 PM
RacerX's Avatar
lube your chasis points. BJs, Tie Rods and the Control Arm bushings
Old Oct 3, 2010 | 9:03 PM
That's going to be difficult since only the two tie rod ends have zerks.
Old Oct 4, 2010 | 2:22 PM
RacerX's Avatar
how so? you get a can of white lithium grease and spray it right inside the control arm bushings, 4 on each side. While you re at it spray some on the bushings for the front susp. and sway bar link bushings also.
Old Oct 4, 2010 | 7:42 PM
mtyler7807's Avatar
that sound is usually a ball joint. If you are turning to the right and you here the sound from the right it is the lower right BJ. If you are turning right and you hear it from the left then it is the upper left BJ. same thing for the other side just reversed. I had a lot of BJ problems with my 26" inch wheels. Change one BJ every 6 months or so.
