Cruise Control 01 Tahoe
Hello Everyone, I need help for my cruise that quit working. this happened sometime after installing new LED taillights. Don't know if this would have caused the problem or not. Anyone had this problem?
RE: Cruise Control 01 Tahoe
Problem is probaly to do with the LED's. The cruise module needs to use the filament in the bulbs as a path to ground for it to work. You could use a relay to open the light blue wire at the cruise module. Have the cruise side of the wire go to ground through the relay, then the car side of the blue wire to activate the relay and lift the ground.
pcwilcox
October 21st, 2013 11:00 AM
liljoe66
August 5th, 2011 12:44 PM
tkdunn
June 20th, 2010 11:15 PM
