Cruise Control 01 Tahoe
Old Aug 10, 2008 | 10:08 AM
Ronmac's Avatar
Default Cruise Control 01 Tahoe
Hello Everyone, I need help for my cruise that quit working. this happened sometime after installing new LED taillights. Don't know if this would have caused the problem or not. Anyone had this problem?
Old Aug 10, 2008 | 6:13 PM
Default RE: Cruise Control 01 Tahoe
Welcome to the Tahoe forum. It'd be a pain but you could put the OEM lites back in to see if the LEDs are the problem.
Old Aug 10, 2008 | 8:48 PM
I know its simple and maybe obvious but as shawnvw said in another post...did you check the fuse?
Old Aug 11, 2008 | 4:19 PM
shawnvw's Avatar
Banned
Problem is probaly to do with the LED's. The cruise module needs to use the filament in the bulbs as a path to ground for it to work. You could use a relay to open the light blue wire at the cruise module. Have the cruise side of the wire go to ground through the relay, then the car side of the blue wire to activate the relay and lift the ground.
pcwilcox
Oct 21, 2013 11:00 AM
liljoe66
Aug 5, 2011 12:44 PM
tkdunn
Jun 20, 2010 11:15 PM
kbridge234
Sep 4, 2008 10:03 AM
98tahoe48
May 29, 2007 6:17 PM
