Dash lights
Old Apr 13, 2011 | 10:50 AM
gonz001's Avatar
Default Dash lights
I have a 2003 Tahoe. Just yesterday, backing out of my garage, I noticed that all the instrument lights were off. At lunch they were back on. Same today. On the way to work, they came on. It seems like when the headlights are on, the instrument lights are out. Has anyone seen the same issue?
Old Apr 13, 2011 | 11:36 AM
EinST's Avatar
Welcome to the forum. Are you sure you didn't dim the illumination all the way down?
Old Apr 13, 2011 | 11:49 AM
gonz001's Avatar
Default Dash lights
They are automatic headlights so they are untouched for the most part. Even the DIC display is dark which it would not be with the lights dimmed. Once the headlights turn themselves off, the dash lights come on without anything being touched.
Old Apr 13, 2011 | 11:54 AM
EinST's Avatar
The reason I was asking was, the illumination dimming function gets overridden during the day.
Old Apr 13, 2011 | 12:00 PM
gonz001's Avatar
Thanks. If I cover the sun sensor on the dash, when the headlights come on, the dash lights go off. When I uncover it, the headlights go off and the dash lights come back on
Old Apr 13, 2011 | 5:07 PM
EinST's Avatar
Okay, that proves the ambient light sensor works. Now, can you confirm the illumination brightness setting on the thumbwheel next to the headlamp switch?
Old Apr 13, 2011 | 8:54 PM
Might want to give the dimmer a few good turns to each extreme to reduce any oxidation build up on the dimmer, sometimes just sitting there at one setting can cause poor conductance after a while and moving the contacts around can do some self cleaning...
Old Apr 14, 2011 | 8:52 AM
gonz001's Avatar
Default Did The Trick
Seems to have worked. Thanks Jeff.
Old Jan 8, 2013 | 9:58 AM
lovemytahoe70's Avatar
I have this same problem with my 2002 Tahoe. If the headlights are on, the dash lights go out, except for if I turn the dimmer switch all the way up to turn on the interior dome light...then the dash lights come on. As soon as I turn off the interior dome light, the dash lights go out again. What should I try????
Old Feb 9, 2022 | 1:39 AM
ace ace's Avatar
Default . If the headlights are on, the dash light are off
i have the same issue on a 2002 subk1500 wondering if you ever found the problem or solution other than removing the dome light bulbs
hzlq57
Jun 7, 2016 2:06 AM
devolic
May 18, 2012 9:04 PM
crapalier
Dec 18, 2011 5:34 AM
TxFire
Jan 10, 2011 10:29 AM
Big_Jazzer
Feb 27, 2009 1:25 PM
