Disable sensor on low beams
Old Nov 26, 2006 | 6:36 PM
LTZ_HOE's Avatar
Default Disable sensor on low beams
Any idea how to disable the sensor that turns on the lowbeams to a 07 tahoe? Any information would help greatly.
Old Nov 26, 2006 | 6:45 PM
jlenkows's Avatar
Default RE: Disable sensor on low beams
My most radical thought would be to simply unplug it at the sensor (or just remove the sensor completely.
Old Nov 26, 2006 | 6:51 PM
LTZ_HOE's Avatar
Where would the sensor be located?
Old Nov 26, 2006 | 6:54 PM
jlenkows's Avatar
It's that little greyish dome in the center of the dash where the dash meets the windshield.
Old Nov 26, 2006 | 7:08 PM
LTZ_HOE's Avatar
Any idea on how to disable that without ripping up my dash board? Do you know if there is a fuse I can pull instead?
Old Nov 26, 2006 | 7:46 PM
sjenkinzz's Avatar
Why do you want to disable?
Old Nov 26, 2006 | 8:03 PM
LTZ_HOE's Avatar
Because I have a set of HIDs that I don't want to burn out. I want to be able to turn on my headlights manually.
Old Nov 26, 2006 | 9:10 PM
jlenkows's Avatar
According to the Tahoe manual (page 209)...
Turn the control to this position to turn
off the automatic headlamps and daytime
running lamps (DRL). Turning the headlamp
control to the off position again will turn the
automatic headlamps or DRL back on.
Now last time I checked, the off switch is a momentary switch...
Here's the link to the manual: www.mygmlink.com/pdf/go2content/manual/US/en/chevrolet/2007tahoe.pdf
Old Nov 26, 2006 | 11:06 PM
xclusive's Avatar
the problem with doin this is like u said it momentary switch so u have to do this everytime u get into the truck, which is a pain... are you sure the ball in the center of the dash is the sensor. i thought it might have been the built in compass...
ORIGINAL: jlenkows
Old Nov 26, 2006 | 11:08 PM
xclusive's Avatar
get the top of the dash apart is easy...u need to pop 6 clips and it will come right off...i would use a plastic panel popper to get it off though this way there is less chance of you scratching the dash...
ORIGINAL: LTZ_HOE
