Distributor replacement help
Old May 23, 2021 | 10:32 AM
Chrazyman's Avatar
Default Distributor replacement help
I have a 1999 Tahoe 5.7. It was running decent before, but felt a little sluggish and the check engine light came on showing the P1345 code. I am trying to replace the distributor, but having trouble. I've lined up the marks on the balancer with the notch on the block while also lining up the distributor cap. After installing it yesterday, I couldn't get it to fully startup. It would sputter a few times then die. I set everything again and believe I was a tooth or two off on the gear at the base of the distributor. I rotated the distributor one tooth and now it cranks, but immediately revs up to 5000 rpm, then dies. I'm at a loss now and I don't want to do anything else in fear that I might damage the engine. Need some guidance please.
Old May 23, 2021 | 1:33 PM
Chrazyman's Avatar
Default Solved - Brake hose not connected.
Brake hose wasn't reconnected.
Old May 23, 2021 | 3:01 PM
kevinkpk's Avatar
Thanks for posting the fix!
Ryanater
17
May 8, 2025 12:44 AM
Hiattech
Feb 10, 2020 10:14 AM
metalman1232
Feb 24, 2014 12:16 AM
meetmonk
Mar 13, 2012 11:00 PM
xtepx91
Apr 25, 2008 9:41 PM
