Do alum calipers "Often Fail" after brake-job?
Old Jan 7, 2015 | 6:27 AM
ronboc's Avatar
Default Do alum calipers "Often Fail" after brake-job?
One e-brake shoe is dragging on wife's '02 Tahoe, and the caliper-bracket bolts are so tight I can't get them off to get to the e-brake.
Took the 'Hoe to the local fix-it shop and asked them if they would at least loosen the bolts, and/or do the rear brakes for me. I got this big speech about how the aluminum calipers on that model will likely warp once they've been removed/replaced during a brake-job, and how I'll therefore need to have new calipers installed. 'Quote' came to $500 just for the rear.
This is my first GM product in many years but I never heard of a caliper issue, and would like to hear if it's true. Anyone?
While I'm on the subject... how DO you get those bolts loose? I tried my impact-driver as well as my socket-wrench with a cheater-bar, but no joy. What's the trick?
Thanks!
Old Jan 7, 2015 | 10:27 AM
Was unaware that they were using aluminum calipers. That being said, I have good luck using Kroil which is available only online. Let it soak for at least several hours if not a day. Also you can try a heating and then soaking again.
Dash
May 4, 2020 1:19 AM
boss302beav
Oct 8, 2014 8:53 PM
northrol
Uplander
Feb 28, 2014 2:19 AM
Son_Of_Thunder
Jan 5, 2012 8:20 PM
