Do I have a wiring harness issue? 21 faults
Old Feb 24, 2025 | 6:03 PM
Bgilbert9's Avatar
Default Do I have a wiring harness issue? 21 faults
I’ll spare you all the long details of everything, I own a number of vehicles and rent them commercially and personally. I have not seen my suburban for six months as well. Last I was able to contact the person renting it was in December when they installed a new motor mount. I had to repossessed the car and it’s running pretty rough right now. There are 21 faults and I’ve whittle down some of the problems.P0030 ho2s heater control circuit bank 1
P0031 ho2s heater control circuit low bank one
sensor one
P0050 bank 2 sensor 1
P0051 bank2 sensor 1
P0443 evaporative emission system, purge control valve circuit
PO458 evaporative emissions system, purge control valve circuit low
PO6DA manufacturer control
P3403 cylinder one deactivation intake valve circuit low
P3427 cylinder 4 deactivation
P3443 cylinder 6 deactivation
P3451 cylinder 7 deactivation
I know this is only 11 but most faults have two codes thrown for the same issue so I’ll save room.
1 4 6 7 cylinders means cylinder deactivation cylinders are the failing ones.
But then there’s knock sensors and O2 sensors going off as well. Anybody ever have an issue like this or have any clue as to where I should start?
MySunroofWorks
Apr 20, 2024 9:27 AM
Rpm06
May 17, 2023 11:09 AM
blakevan
Feb 12, 2022 4:17 AM
OnDaGround
Feb 1, 2019 12:23 AM
rabbit0102030
S10 & Blazer DIY and Useful Threads
Mar 5, 2014 7:36 PM
