Does a cold air intake have more benifits than problems?
Old Oct 10, 2017 | 11:26 AM
rightstuffer's Avatar
Newly Registered
Default Does a cold air intake have more benifits than problems?
1999 Chevy Suburban K1500 new factory stock motor. Would a K&N cold air intake and max flow mas air sensor be a good modification for a stock crate GM motor? Or would it introduce reliability and check engine light problems?
Old Oct 10, 2017 | 8:08 PM
stay stock. always use factory brand air filters. almost all high flow filters flow more by filtering less...they don't meet oem filtering standards...good way to get dust out conditions. I have quite a few vehicles with cai/filters as the only mod and imo...they add zero hp. they are jewelry. If i was building a race car...would be the only time i use it.
Old Oct 10, 2017 | 9:43 PM
rightstuffer: Welcome to the forum.
+1 on what tech2 said. The dyno sheets I've seen show a very modest (5-7) hp increase occurring at 5,000 rpm and up.Not something you are going to notice unless you going for a high speed run. What you can notice w/ the butt dyno is torque and to increase that usually means cam change, etc.
Old Oct 11, 2017 | 10:21 AM
SabrToothSqrl's Avatar
if <a company> could get more <reliable> HP by simply changing a filter/box... they would have.
Old Oct 11, 2017 | 8:42 PM
cai can even make it worse. If you take out the resonator box part of the intake snorkel; it creates a buffeting effect that reduces airflow...intake air hits the throttle plate crates a pressure wave the pushes back against incoming air. google resonator box purpose
Old Oct 12, 2017 | 7:40 PM
I thought another purpose of the resonator box was to reduce the WOT induction noise.
Old Oct 12, 2017 | 8:33 PM
multiple functions...goggle it....better explanation then i can give.
