rear brakes hot
Old Sep 16, 2017 | 5:32 AM
tahoe64gg's Avatar
Default rear brakes hot
I was pulling 4000 lb travel trailer and noticed the brake pedal went to floor, but would pump back up after I first lost the pedal. I could smell brakes and checked vehicle master cylinder which was full of brake fluid, then I checked the rear brakes were very hot. I recently replaced emergency brakes on the rear. What could be the problem with the rear brakes? Thanks in advance. Terry
Old Sep 16, 2017 | 9:28 AM
model year, engine, rear drum or disc?
Old Sep 18, 2017 | 5:24 AM
tahoe64gg's Avatar
I have a 2002 Tahoe LS rear disc brakes and 5.0L engine.
Thanks
Old Sep 18, 2017 | 10:04 AM
Miami Son's Avatar
No trailer brakes on something that heavy?
Old Sep 18, 2017 | 11:03 AM
02Sub's Avatar
Thanks
Do you mean the 5.3L engine?
Are both rear brakes hot?
Are they only hot when towing?
The parking brake shoes might be dragging, overheating the caliper and therefore overheating the brake fluid.
I had a similar issue with my 2002 Suburban, I had one rear brake get very hot when I started pulling my travel trailer. In that case, the pad was sticking due to rust on the caliper where the pad ears slide. I loosened up the pad and everything was fine. I didn't have any pedal fade though.
Steve
Old Sep 18, 2017 | 12:29 PM
Frank3's Avatar
My 2002 Tahoe did the exact same thing. I eventually found out the pistons on the front calipers were frozen in the caliper body causing pretty much most of the braking to be done with the rears. One rear caliper got so hot it burned the dirt seal around the piston partially off. New calipers all the way around got things working evenly again.
Old Sep 19, 2017 | 5:38 AM
tahoe64gg's Avatar
Steve
Yes, the engine is the 5.3L and both rear brakes were hot. It seems to be doing it with heavy towing only. I pull a 2000 lb boat about 4 miles to the boat ramp and have not noticed any brakes heating up. Thanks for your reply. Is it simple to loosen up the pads as you stated?
Thanks again,
Terry
Old Sep 19, 2017 | 5:41 AM
tahoe64gg's Avatar
Thanks for the reply. I may have to the way you went in replacing all the calipers. The car has 255,000 miles maybe they are due.
Thanks again,
Terry
Old Sep 19, 2017 | 5:45 AM
tahoe64gg's Avatar
Yes, I have the trailer tow package, but my travel trailer E-brakes have a error message of wiring fault on trailer. I stay on the flat lands when pulling. I do need to fix my TT E brakes.
Thanks,
Terry
Old Sep 19, 2017 | 9:01 AM
02Sub's Avatar
Thanks again,
Terry
What happens is that rust forms under the thin metal snap-in shims that the brake pad ears ride in. The rust squeezes the shims and the ears get hung up. I cleaned out the rust with a wire brush and also ground off a little material from the edges of the brake pad ears so the would slide in and out easily by hand.
Steve
