rear brakes hot
Old Sep 19, 2017 | 9:06 AM
  #11
02Sub's Avatar
Also, I agree with Frank3 that the rears should not be working so hard. Definitely check the front calipers to see if they slide in and out freely. When a caliper sticks, the inner pad is worn much more than the outer pad because the piston pushes on the inside pad whether the caliper sticks or not.
Old Sep 19, 2017 | 12:38 PM
  #12
Miami Son's Avatar
Originally Posted by tahoe64gg
Yes, I have the trailer tow package, but my travel trailer E-brakes have a error message of wiring fault on trailer. I stay on the flat lands when pulling. I do need to fix my TT E brakes.
Thanks,
Terry
So you're pulling a trailer equipped with electric brakes, but they are not being used and you're wondering why your truck's brakes are overheating? smh
Old Sep 20, 2017 | 5:28 AM
  #13
tahoe64gg's Avatar
Thanks for the information. I will check.
Old Sep 20, 2017 | 5:30 AM
  #14
tahoe64gg's Avatar
Thanks for the information. I will try the method you are referring too.
Old Sep 21, 2017 | 4:05 PM
  #15
Matt B's Avatar
Important to note that the rotors are designed to get pretty warm.. 4000# is about all I'd be comfortable pulling with the 1500.
Are they too hot to touch hot, or just very warm?
Old Sep 22, 2017 | 9:39 AM
  #16
if the rear calipers were seized or dragging; you would be smelling burnt pad, and the rim would be to hot to touch.
Old Sep 23, 2017 | 6:02 AM
  #17
tahoe64gg's Avatar
What happens is that rust forms under the thin metal snap-in shims that the brake pad ears ride in. The rust squeezes the shims and the ears get hung up. I cleaned out the rust with a wire brush and also ground off a little material from the edges of the brake pad ears so the would slide in and out easily by hand.
Steve
Thanks for the advise.
Terry
Old Sep 23, 2017 | 6:07 AM
  #18
tahoe64gg's Avatar
Yes, rear brakes did smell and they were to hot to touch.
Old Sep 23, 2017 | 6:10 AM
  #19
tahoe64gg's Avatar
Yes, they were to hot to touch.
Old Sep 25, 2017 | 5:33 PM
  #20
Matt B's Avatar
Could be Sticky bracket where the pad sits in the clip on the Mounting bracket, sticky piston in the caliper, sticky slide pins on the caliper.
Clean up the bracket and reinstall the clip, check for free-floatyness of the pads. Checkout pad life.
I don't know what shape your rigs in. My 07 came from our Canadian brothers up North and was quite rusty from they day I got a screamin' deal on her.
If yours is anything like mine was it might be easiest to jump ahead and replace those cracked brake hoses and trade out for some re-manufactured calipers. Guy could even do all four if he wanted to get carried away...
