door locks
Old Feb 24, 2011 | 6:34 PM
zeke8226's Avatar
Default door locks
second door won't lock, was wondering if the accuator would lockup to the point that you can't even move the rod to try and lock by hand?
Old Feb 27, 2011 | 7:27 PM
chad_18's Avatar
I believe you can still move the rod by hand and it may not actually be locked up. I had an 08 Avalanche into the dealer 3 times for the problem... Long story short, they replaced the whole system. The single door with that problem was now fixed but then some of the other doors did not unlock on occasion. I'm sure this wasn't much help, just sharing the experience...
Old Feb 27, 2011 | 7:48 PM
LARIDERS's Avatar
I have had accuator's go bad before. once you take the door apart you should find your problem. accuator will not cost much.
Old Feb 27, 2011 | 9:27 PM
RacerX's Avatar
yep, especially if they are power door locks. the solenoid is at the bottom of the door and is where water will freeze and rust in the winter time. They cover it with a thin rubber seal with over time, dont count on it.
Old Feb 28, 2011 | 3:28 AM
zeke8226's Avatar
got the accuator out and it was froze up replaced it and works fine. sprayed wd 40 on the old one broke it loose and plugged it in and works just fine will keep as a backup.
thanks for the help!
CKFords
Mar 5, 2019 2:17 AM
eric1ad
Sep 19, 2017 12:36 PM
davbell22602
Mar 10, 2010 8:36 PM
disastro
Jul 26, 2006 9:09 PM
cookie
Jul 7, 2006 2:30 PM
