Driver door speaker
Old Dec 28, 2015 | 5:16 PM
Nadams0298's Avatar
Default Driver door speaker
I have an 05 tahoe. The driver side speaker was cutting in and out. My fiancé got me a new stereo and door speakers due to factory CD player eating CDs and one back speaker being blown. After putting new stuff in we noticed the driver speaker is still not working completely. The tweeter works fine but the bass producing part doesn't. Anyone know how to go about finding the issue? I tried following the wires to see if maybe one was cut or chafing to make it not work but, all the door control wire are bundled together and I didn't want to unbundle them I not necessary. The factory system was basic (not Bose) if that helps. Thanks!
Old Dec 28, 2015 | 11:01 PM
justimagination's Avatar
Hate to spoil it for you after all the work..............but new radio/spks and still same problem.......bad wire somewhere. Myself, I would attach a speaker wire to the adapter plug that you used for the factory connector, and run it to the l/door. You can push it through the rubber grommet that holds the harness, that is JMHO. Good luck.
David g.
Old Dec 29, 2015 | 11:21 AM
Nadams0298's Avatar
David g.
Thanks for the input! I had already been brainstorming and figured that would be the easiest, most hassle-free way to deal with it. But, wanted to make sure there wasn't a more simple fix to the problem. It shouldn't take too long (fingers crossed). Thanks again!
