Driver's main switch can't roll down or unlock passenger door
Strange thing happened this morning. When I got in and started my '07 Tahoe up, the driver's main switch couldn't unlock the front passenger door and it couldn't roll that same window up or down. The driver's switches for the other passenger doors and the driver's door worked fine. Also, the switches on that door worked fine to unlock/lock and roll up/down the window. I was in a hurry to drop the kids off at school, so I used that door's switch to roll the window up. As I put it in gear to start, the automatic lock feature locked all the doors, except for the front passenger. Anyway, when I got to the school and parked, shut off the engine, and locked the doors with the remote. The remote locked all the doors! The remote also unlocked all the doors as usual. Once I unlocked the doors with the remote, the driver's main switch was once again able to unlock all the doors and also work all the windows. Very strange.
RE: Driver's main switch can't roll down or unlock passenger door
There is a reprogram your dealer can do for this. They will reprogram your vehicle the with updated software for you Driver's Door Switch and PDS. It should resolve the issue. I had this done a long time ago and everything is fine now.
See this thread for other reprogramming info...
https://chevroletforum.com/m_14997/tm.htm
Guest
Posts: n/a
haidangwa, I've had this happen too, and got the dealership to do the required fix, but it still seems to come back every now and then. I am in the process of trying to get them to fix it again, but they say they can't reproduce the problem since it doesn't happen all the time.
As it says in the linked thread. Some dealers are not good at doing the reprogram upgrades. Make sure they use the prescribed "passthru" method
Have the dealer reprogram the driver door switch (DDS) and passenger door switch (PDS) using SPS and Pass-Thru method, with updated software calibrations.
Been having some issue with these little guys holding data correctly lately.
One error that dealers are commonly making when the reprogram the modules with these updated calibrations is that some are not using the Pass-Thru method.
You may want them to try it again and stress that they need to use the Pass-Thru method to complete this proceedure
polpower
August 19th, 2013 10:42 PM
