driver's seat craziness....
Old Jan 19, 2007 | 1:04 PM
graphicguy's Avatar
Default driver's seat craziness....
New '07 Tahoe LTZ owner. I find that no matter if I activate the "easy exit" feature or not, whenever I get in the driver's seat, it's about 6 inches closer to the steering wheel than when I last exited. It doesn't slide back (which is what I thought it was supposed to do with "easy exit). It slides way forward (making it a squeeze to get into the seat). I'm not a big guy.....5'10"....180 lbs. Is this right.
It doesn't seem to matter whether the "easy exit" feature is activated or not.
Any suggestions/solutions/advice?
Old Jan 19, 2007 | 9:06 PM
engine2's Avatar
Default RE: driver's seat craziness....
Did you set your seat memory locations?
Old Jan 19, 2007 | 9:40 PM
tahoe07's Avatar
If someone accidentally set the seat memory to the "closer" postion then whenever you use the remote to unlock the door it sets it to the that postion.
Get in and set the seat position. Then hit and hold the memory button on the door until it beeps. It should remember that position. It sounds like you already do, but check to see if you have the memory seat recall "on" in the DIC. If so it will recall the saved setting.
Old Jan 20, 2007 | 1:37 AM
Also be aware that each key fob is assigned a number 1 or 2 (used to be on the back). So when you set Memory 1, you'll have to determine which fob controls that setting.
Old Jan 20, 2007 | 11:08 AM
tahoe07's Avatar
Good point, Shark.
I am the only one driving my Tahoe so I set both 1 and 2 to the same position so I could grab either Fob.
Old Jan 20, 2007 | 3:32 PM
haidangwa's Avatar
Yeah, matching the number on the fob with the memory position is key (pun intended). Initially, I set my memory positions on #1 and my wife set hers to #2, but our fobs actually reversed. I should have set mine to #2 and hers to #1.
Old Jan 21, 2007 | 12:43 AM
tahoe07's Avatar
I miss the numbers onthe back. Guess they are ore simple to produce and supply without the numbers to worry about.
Old Jan 21, 2007 | 12:55 AM
engine2's Avatar
ORIGINAL: 73shark
Thanks for the info. I just happen to be using the correct FOB and did not realize each had its own. Makes perfect sense.
Old Jan 21, 2007 | 6:27 PM
Based upon how long the printed instructions on the back of mine lasted which was about a month, I guess it's a moot point whether or not they put the numbers on the back or not.
My wife's 2004 Tahoe still has the numbers and my ex-2002 TrailBlazer both still had the numbers and were still very readable.
Old Jan 22, 2007 | 12:36 AM
tahoe07's Avatar
They were molded into the fob itself.
