DRL Module location
I finally found the module location. It was a gray plastic box wrapped with the large wire harness. Once I removed the tape around the harness I found the box and there is an opening on the top with wires on the bottom. Once you open the top, the module can be pulled out with pliers and the new one went right in. DRL now working again.
The module box was located on the left side of steering column (facing steering wheel) and it was wrapped in electrical tape to the thick harness of wires. The module was completely taped over when I found it. Look for a large bump in the wiring harness.
