Dual camera with Nav. unit
Old Mar 6, 2007 | 11:29 PM
silverzz28's Avatar
Default Dual camera with Nav. unit
I installed a nav unit with a aftermarket backup camera. I would like to mount another camera inside of the truck. I installed the plug for the vss,etc from jp customs which put the output for the one camera.
Question is can you make this unit work with another camera was well? I remember reading about it but I can't find the thread.
Also this unit is the DVD model. does the unit have outputs for the dvd system on the back as well? for a monitor
Hope that made sense []
Old Mar 6, 2007 | 11:46 PM
kcw002's Avatar
Default RE: Dual camera with Nav. unit
I am just an normal guy and I think understood... How many AV inputs do you have on that unit..? You should be able toswitch AV1 / AV2 for the two cameras.. My bud has a Kenwood Ddin w/ 2 cams. Back up camand a camin theback seat... Easy boys... its to watch the baby You unit should also have Video outputs - 1 or 2....This will allow you to send the source vidoe to other monitors...
I am sure the guys will want to know which unit you have before they dive too deep...
Old Mar 6, 2007 | 11:50 PM
gm_geek's Avatar
You can add second camera. on 07 gets a little tricky and sometimes expensive. but it's been done.
as far as audio/video out from Your factory DVD, was done as well. basicaly I was able to duplicate factory RSE option, and was even able to use factory remote control. cost me about $200 for some extra parts. but worked just like a factory one
http://www.cadillacforums.com/forums...eo+integration
Old Mar 7, 2007 | 12:05 AM
kcw002's Avatar
good thing the real deal guys are here..... I thought you were 100% aftermrket. sorry...
Old Mar 7, 2007 | 12:21 AM
gm_geek's Avatar
ORIGINAL: kcw002
I do both. factory or aftermarket. what ever my customers/dealers wish for
Old Mar 7, 2007 | 12:54 AM
TMW597's Avatar
Have you seen the latest version of the GMLockPick? Not sure if it will work with the aftermarket camera though.
http://www.coastaletech.com/./media/mp_GMCAM_1.asx
http://www.coastaletech.com/GMCAM.htm
This post talks more about it too: https://chevroletforum.com/fb.asp?m=23489
Old Mar 7, 2007 | 1:08 AM
gm_geek's Avatar
I actually had to use lock pick for dual camera set up in one of the cases. not coastall piece, but similar one
problem with coastal is those guys a worst buseness people I've ever deal with. you can never get hold of them, don't reply for your e-mails
Old Mar 7, 2007 | 12:06 PM
RockstarDaddy's Avatar
ORIGINAL: gm_geek
GM,
Was it cheaper?
Old Mar 7, 2007 | 12:54 PM
gm_geek's Avatar
Rockstar
was not that much, only like $50 cheaper
Old Mar 7, 2007 | 1:20 PM
knute3's Avatar
ORIGINAL: gm_geek
Do you have a link to another company besides coastal for the lockpick? They are horrible.
