electrical issue
Old Jun 5, 2015 | 9:41 AM
bnorris711's Avatar
Question electrical issue
Someone please help! The power windows and windshield wipers continue to work in my 02 Tahoe even after the key is out, door has been opened, and the 10 minute delay has passed. It is causing my battery to drain and die on me. I have checked all fuses, relays, and even replaced the BCM. Any help would be awesome!!
Old Jun 6, 2015 | 6:13 AM
a55bruce's Avatar
Originally Posted by bnorris711
The power windows and windshield wipers continue to work in my 02 Tahoe even after the key is out, ...
The wipers are not on the 10 minute delay circuit. I'd look at the ignition switch as a possible culprit.
Old Jun 6, 2015 | 2:28 PM
Rednucleus's Avatar
What a big surprise if a Chevy ignition switch was found to be a problem!
Old Jun 9, 2015 | 11:51 AM
bnorris711's Avatar
Thank you a55bruce. I was thinking about trying to replace the ignition. Just tired of sinking money into "fixes" and them not working. The ignition will be my next purchase though!
Old Jun 9, 2015 | 11:58 AM
Before buying and replacing the switch, you might try pulling the column shroud off and checking the wiring, making sure noting is melted pinched or rubbed bare first...
Old Jun 9, 2015 | 12:25 PM
a55bruce's Avatar
Agree w/ in2pro. Are there any other circuits that still have power with the key out? Rear wipers, radio, washer pumps, etc... Power can be back-fed into the circuits from bad wiring.
Old Jun 9, 2015 | 12:33 PM
bnorris711's Avatar
I have taken everything apart and there are no obvious issues with the wiring. The person who owned the vehicle before me had an aftermarket CD player and remote start put in. I have taken all of that out, along with all of the extra wiring that it entailed. The only things that work while the vehicle is off & key is out are the power windows (All 4 of them), and the windshield wipers are fully functional.
Old Jun 9, 2015 | 3:33 PM
a55bruce's Avatar
...aftermarket CD player and remote start put in. I have taken all of that out, along with all of the extra wiring that it entailed. The only things that work while the vehicle is off & key is out are the power windows (All 4 of them), and the windshield wipers are fully functional.
I take back my guess of the ignition switch. If the widows are working but NOT the radio, AND the rear window wiper is NOT working, then you have some left over wiring you haven't found yet. Pull out the RAP#1 & RAP#2 relays. Do the windows and wipers still work? Do the relays click when pulled out or put back in? If the drivers door is open (key off) these relays should not be energized.
Old Jun 10, 2015 | 7:39 AM
bnorris711's Avatar
I do not have a rear wiper on mine and the CD player that is in it now is still an after market CD player, just not the one that the previous owner had wired up. The wipers and windows all still work with the relays out. The relays do not click when pulled out or put back in. I even put new relays and fuses in but it did not fix anything.
Old Jun 10, 2015 | 9:04 AM
a55bruce's Avatar
What troubles me is if the wipers are working, then everything that is powered with the key in acc/run should also be powered-up (radio, dash, wiper, washer, widows...). Does the radio turn OFF with the key out? What fuse are you pulling to stop the power drain? Do you have a voltmeter or a 12V test light? With the key OFF and the door open, pull the RDO-1 fuse and the WS WPR fuse. Do the windows/wipers still work? Test the fuse sockets, do any of the fuse connectors show power? Then turn the key to ACC., re-check the fuse sockets. Which terminals now have power?
dcarlton
13
Oct 15, 2023 10:05 PM
GoGibbs
Aug 8, 2007 7:37 AM
gmlover
Corvette
Mar 21, 2007 5:52 PM
