Engine RPM-related harmonic noise from passenger-door rear speaker
Old Feb 22, 2025 | 7:54 PM
rjdjbd's Avatar
Default Engine RPM-related harmonic noise from passenger-door rear speaker
2003 Suburban K-1500 LS
I have an RPM-related harmonic noise from passenger-door rear speaker. It’s been there for quite sometime and can’t pinpoint when or why it might have started. The noise is only when the radio is on and the engine running and is only from the passenger-side rear door speaker. The pitch changes based on RPM. I had previously discovered that if I disconnect the Rear Audio Panel, (Radio Control - GM 15850811, discontinued, no longer available) leaving me with front speakers only, the noise is gone. But that also takes out the use of the DVD player.
Any ideas on how to diagnose the actual problem… is it the Rear Radio Control, a grounding issue to the radio or at the Rear Radio Control, the rear speaker, etc?
Thank-you
rjdjbd
Old Feb 26, 2025 | 10:59 AM
rjdjbd's Avatar
mstewart39
Feb 13, 2018 11:51 AM
KHD
May 24, 2014 4:33 PM
bebop123
Sep 19, 2013 11:38 AM
jbsavage_24
Jan 23, 2012 6:54 PM
butchermanj
Sonic (Aveo)
Nov 21, 2007 10:50 PM
