engine running rough
Old Jan 8, 2008 | 4:33 PM
ussva's Avatar
Default engine running rough
I have a K2500 suburban with a 7.4 liter engine. I initially thought I pumped some gas with water in it, (small town above ground tank) I added gas antifreeze and some fuel injector cleaner but nothing changed. I checked my plugs, they were ok, still gapped at .060, changed my air filter but still no change. There is no "check engine" warning light and sometimes it is slow to start, like it's not getting fuel? Any ideas?
Old Jan 8, 2008 | 4:39 PM
ZX1100F1's Avatar
Default RE: engine running rough
Fuel filter?
Fuel pressure regulator?
Dirty Injectors?
Old Jan 8, 2008 | 4:56 PM
ussva's Avatar
Bought a fuel filter, haven't changed it yet, might be that?
Old Jan 8, 2008 | 5:00 PM
ZX1100F1's Avatar
Fuel filter is the #1 cause.
Old Jan 8, 2008 | 5:11 PM
ussva's Avatar
Don't have a repair manual, is the fuel filter located on the frame close to the gas tank?
Old Jan 8, 2008 | 8:02 PM
ZX1100F1's Avatar
Inside frame rail under driver door.
Old Jan 8, 2008 | 8:32 PM
ussva's Avatar
Thanks for the info, I'll try the fuel filter, hopefully that works. Keep you posted.
Old Jan 8, 2008 | 8:37 PM
ZX1100F1's Avatar
Dump about six 12oz bottles of Techron fuel system cleaner in a full tank of fuel and run it until it is close to empty before refueling while you're at it, it'll make it feel like a new engine.
http://www.chevron.com/products/ourf...tives/tcp.aspx
Old Jan 8, 2008 | 8:50 PM
ussva's Avatar
I'll try that, thought of taking it to the local chevy dealerfor a diagnostic but, labor and other charges! Thanks again.
sittinlow88
Nov 5, 2021 5:08 PM
macmommy
Apr 22, 2020 1:23 PM
Jro
Oct 14, 2007 2:16 AM
350Boy
Apr 8, 2007 10:51 PM
btotheh33
Mar 11, 2007 3:30 AM
