Engine swap?
Old May 7, 2012 | 6:50 PM
gatrdet's Avatar
Default Engine swap?
Hi All,
I have a '98 chevy suburban with a small block V-8 350 - with a blown rod. I might have a deal $$$ on a 8.1L Big Block 496 V8 Chevy from a pick-up. Anybody know if I can exchange the small block for the big block without much fuss?
Thanks
Jay
Old May 7, 2012 | 9:19 PM
Welcome to the forum.
I doubt it. Mounts, exhaust, computer(s), tranny mounts, etc will be different most likely. Of course, it depends on your def'n of fuss.
Old May 7, 2012 | 9:31 PM
Exhausted's Avatar
Yes you can do it
Yes it would be a bg fuss
If I were you I would look for an LT1
Old May 8, 2012 | 8:46 PM
gatrdet's Avatar
Thanks for the info - will consider other options. Still have to pull off the manifold to see why she's banging... Guess I'll make decision after getting a peek. Anybody know how I can pull off the AC without it blowing up in my face? I'm a novice and very much appreciate any/all advice. Any suggestions on books too?
Old May 8, 2012 | 11:12 PM
jeffsw6's Avatar
Another point against the 5.7 to 8.1 swap is the 4L60 is simply not made to handle the torque of the 8.1, and if your truck is a half-ton 4x4, it will probably put you over the front axle weight capacity. In short, pretty big project.
cueman
Feb 6, 2012 9:37 PM
BigSteve1206
May 16, 2006 8:50 PM
cleveman1
May 1, 2006 1:05 PM
Iowajeepin
Chevelle & El Camino
Apr 2, 2005 1:50 PM
