Entertainment system ~ Not Working
Old Nov 3, 2011 | 10:53 AM
Tee.M's Avatar
Default Entertainment system ~ Not Working
I have a 2011 Surburban LTZ, and the entertainment system is not powering up. Upon starting my vehicle, there is only a blank screen. No sound, no navigation ,no power, no rear camera, it's totally dead. I also checked the fuse (#16 accessories) and it is fine. Does anyone have any knowledge on this type of problem. Please advise....Thanks!
Old Nov 3, 2011 | 12:11 PM
ousig2408's Avatar
have you pushed the power/volume button? sorry may be obvious but possible that your screen was turned off under the menu? other than that no clue - hope you have a dealer close to fix or replace it
Old Nov 3, 2011 | 2:28 PM
SabrToothSqrl's Avatar
Default screen
you have a 2011...take it to the dealer.
Old Nov 3, 2011 | 6:00 PM
ChevyFreak's Avatar
My first question is do you have a lock pick? If not, then skip ahead. However, if you do, that could very well be your problem. I can clarify on this if that is the case.
The fuse you should be looking at, I believe is fuse #41 located in the "under the hood" fuse block. That is the "Audio System" fuse. You can confirm this in your manual.
distraction3345
Dec 18, 2006 7:05 AM
sg12
Aug 11, 2006 10:14 PM
sg12
Aug 11, 2006 10:07 PM
sg12
Aug 11, 2006 10:02 PM
