Exhaust donuts
Old Dec 13, 2006 | 1:50 AM
bk94si's Avatar
Default Exhaust donuts
Has anyone else had problems with exhaust leaks where the donut gaskets are? It has been fixed by a mechanic once, by me once, and I can hear it happening again (over about 5 years). Anyone with a fix that will last longer?
Old Dec 28, 2006 | 7:26 PM
Dondobe's Avatar
Default RE: Exhaust donuts
BK94si, I've had the same problem on my "99"(189 K). We had to grind the nubs on the cast iron flange so it will tighten better. Then after we did that the pipe cracked around the flange (fatigued Pipe). That was fixed at a muffler shop by making a new flange and doubling the flange on the pipe(one inside the other ) Ihaven't had any problems since.
Good Luck, Dondobe
Old Jan 7, 2007 | 12:41 AM
n0dih's Avatar
I just replaced the pass side donut on my 99 K2500 454 Suburban and the new one was considered "second design", it was white and thicker. I hope it lasts....
Old Jan 11, 2007 | 11:05 AM
gmpartsland's Avatar
I,ve also had good look with the thick white donuts. I'll keep you updated if they go again
rondo
Feb 21, 2012 10:54 PM
gmag211
Nov 11, 2007 6:25 PM
67impala
Jun 11, 2006 7:34 PM
dppd1511
May 30, 2006 3:43 PM
wvjustin
Dec 29, 2005 9:38 PM
