First problem with Tahoe, but nothing can be done, yet!
So about a month ago I had my first problem with my truck.
2008 Tahoe 3LT 4x4 purchased in Sept 2008 with 5 miles on it. Currently ~5200 miles
The Issue: It was a clear day with an outside temp in the low 40's. I was pulling into a 8 story parking garage and made my first right turn. All of a sudden my truck stopped dead in its tracks. I gave it a little gas and it almost sounded like my right rear tire was dragging and the turning in the front felt like 4x4 was engaged. So I checked the 4x4 **** and it was in 2wd. I made the turn (was forced to as cars were behind me) and 40 feet later I have to make another right turn. Same issue, sounds like dragging rubber in the rear and can't turn normally.
I was forced to keep going forward because the line behind me was getting huge as I was trying to go slow. When I was in a straight area I did try to put it in 4x4 auto, 4x4 hi and lo, but it did not solve anything. So after about 10 right turns I found a spot to turn in (felt like eternity) and as I was pulling into the spot I heard this loud bang in the rear, identical to 4x4 low engaging, and everything was normal again.
I didn't bring it to the dealer as I felt they won't do anything because there is no service engine light and the problem is not there and has never returned. Other than me describing it, nothing for them to look at.
So this has been on my mind for over a month now and I totally forgot about this forum.
Any ideas?
Any ideas?
you said the noise was from the rear? I'm more skilled with Jeeps than GM, but the Tahoe has a rear locker, but I have no idea how it works... sometimes when lockers 'unload' and become an open diff there can be a noise from the rear, and the vehicle will feel like its being pushed and not turning as tight as it should...
just an idea! i'm not familiar with the GM locker... only the wrangler one and after market ones... ARB/OX/NoSlip/etc...
I too have more knowledge about jeep rear ends an lockers, but it may be an issue that the limited slip additive was not properly added at the factory. In my '06 4x4 Silverado, I had some serious dragging of the rear tires while navigating a parking garage. I changed the diff fluid and added the GM additive and the problem was resolved.
I'll let you all know what come of it.
I just got back from the dealer. As I suspected they could not find anything wrong. They took it for a drive and checked fluid levels.
I guess I just need to cross my fingers and hope nothing serious is wrong.
Take it in and get it fixed.
