FNG with another question.......wtf??
Old May 7, 2010 | 10:53 PM
DanielB's Avatar
Default FNG with another question.......wtf??
1. Yes I searched.
2. Yes I read it.
3. When I thought I'd read it all. I tried to fix it.
4. Then repeated 1-3 again.
Now I can't figure it out and I'm gonna set this thing on fire.....
I have a 2007 GMC Yukon XL Denali with a DVD/Navi factory unit. It had a factory overhead rear monitor. Not anymore. Stolen. Now I've got a aftermarket flip down (no built-in dvd) monitor. I've tried to wire it in so many times that I'm to the point on blowing the damn thing up, literally.
I wired the video RCA for the monitor into the pins
From the head unit (fond this pinout from on here)
16-Pin Connector C3:
7 D-GN 6975 DVD Video Signal (+)
15 WH/BK 5335 DVD Video Signal (-)
and nothing worked. Blank screen. I checked continuity from these wires and they show a direct connection to the rear auxiliary inputs between the two front seats which leads me to believe that this may be wired wrong. But if it is, then what the hell wires are the RIGHT ONES!!?!?!
Help me......before I burn it.....
Old May 8, 2010 | 8:26 PM
Have you tried the new monitor w/ another source like a DVD player? Could be a bad monitor.
Old May 10, 2010 | 3:39 PM
DanielB's Avatar
Yep, monitor is good..
So tell me this, did I use the correct wires for the video?
Old May 10, 2010 | 8:53 PM
LARIDERS's Avatar
not sure if this will help. don't know much about the dvd systems.
Video Signals
Dual DVD Headrest System
File Type: pdf
Old May 10, 2010 | 9:13 PM
LARIDERS's Avatar
this is the dual one
Old May 10, 2010 | 10:20 PM
DanielB's Avatar
I have tried for the life of me and can't see a single word on that diagram. Do you have one that can be enlarged and still is readable?
Old May 10, 2010 | 10:30 PM
LARIDERS's Avatar
I can not upload the dual one it says file is to big. pm me you email address I can try and send it that way you so that you can zoom in it will be a pdf like the other one.
Old May 10, 2010 | 10:31 PM
DanielB's Avatar
PM sent. Thanks again.
Chevrolaid
Astro
Jul 6, 2015 10:35 PM
jrollings
Jan 4, 2015 9:35 PM
Neverdone
Mar 29, 2011 5:24 AM
DanielB
May 11, 2010 9:37 PM
motivated1
Nov 28, 2005 5:19 PM
