Front end noise
Old Jan 21, 2012 | 9:22 PM
jbsavage_24's Avatar
Default Front end noise
I thought the bearings were going bad on my 07 Suburban, It is making a noise that sounds similiar to what a mud tire might make. My tires were pretty bad so I went and got new tires. The noise it still there. They checked the bearings and looked for what might be making the noise and no luck. It sounds like it is coming from the front driver side. Any ideas. Thanks in advance.
Old Jan 23, 2012 | 11:33 AM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> jbsavage_24,
It may be your front differential bearing. Front ring and pinion is another possibility. This is not a diagnosis, just suggestions.
I encourage you to take the vehicle in for an inspection. A certified technician should be able to offer a more accurate diagnosis.
Please keep us posted.
If you have additional questions, please feel free to contact me.
Louis
GM Customer Service
TASpinney9110
Mar 15, 2011 5:54 PM
mandrus
Mar 12, 2010 7:45 PM
02blue1
May 30, 2007 11:45 PM
slimnottygirl
Mar 7, 2007 4:40 PM
02TrailBlazer
Mar 14, 2006 2:28 AM
