Fuel meter body plug gaskets?????
Old May 14, 2012 | 8:16 PM
1BDDELX's Avatar
Default Fuel meter body/spider injector plug gaskets?????
Hello everyone Im a newbie here but belong to lots of forums. If you need answers turn to the pros(You Chevy Experts). So here I am.
Long story short I have a 98 Tahoe 5.7 I have fuel spilling out the what I was told was called the fuel meter body/injector/spider injector assembly. I took it all apart and there are 2 gaskets on the plug that plugs into the top of the piece. Question is where do I find those seals????I have searched and cannot locate. Any help is appreciated.
Thanks Jeff
Old May 14, 2012 | 9:49 PM
MDTAHOE's Avatar
Professional Mechanic
I would assume you are talking about the plenum (upper intake) gaskets. 1 large oval type o-ring around the meter body and one around the upper intake? picture if not.
Old May 14, 2012 | 10:00 PM
1BDDELX's Avatar
No Sir not that one, the ones I need are on the electrical plug that plugs into the spider on the top. One is Red and the other is green
Old May 14, 2012 | 10:10 PM
MDTAHOE's Avatar
What happened to the old one? If you are talking about on the large connector then that is not something that gets replaced. You would probably have to buy a new engine harness. It is designed to keep moisture out.
Old May 14, 2012 | 10:16 PM
1BDDELX's Avatar
Its leaking gas out of it onto the plenum. Oh man I certainly didn't want to hear that but yes thats the connector in question. Any other reason why it would be leaking fuel there. I fixed it once today with the old gaskets and it purred like a kitty no problems no fuel leak. As soon as I shut it off the seals popped again and here I am back at square one.
Old May 14, 2012 | 10:18 PM
1BDDELX's Avatar
The plug plugs into this>>>>NAPA AUTO PARTS
I might need to hit the junk yard and cut off a plug if I can find one.
Old May 15, 2012 | 6:57 AM
MDTAHOE's Avatar
If it is leaking fuel out of the electrical connector then your new part is bad. There should be no fuel there
Old May 15, 2012 | 10:02 AM
1BDDELX's Avatar
I didnt change any parts at all. Later today I will take it apart again and post some pics
Old May 15, 2012 | 1:11 PM
1BDDELX's Avatar
Well calling the dealer yesterday was absolutely no help. Went in person today and holy @#$% to my amazement after searching for this part the guy said when would you like? I almost fell over dead. I actually had him overnight it so it will be here in the morning. WOOOOHOOOO Thanks for your time MDTAHOE. I will still post some pics tomorrow in case anybody else has this issue. Hopefully this part has everything I need in the box.
The part ordered was:
<TABLE class=part_list cellSpacing=0 cellspadding="0"><TBODY><TR class=grayline><TD class=td1></TD><TD class=td2>12167618</TD><TD class=td3> CONNECTOR INJR-FUEL,(SCPI),(16-W F W/O LEAD;INCLS CONN,SEAL,TPA,CAP,TERMS,CBLE SEALS,CPA),(03.300)</TD></TR></TBODY></TABLE>
Old May 15, 2012 | 2:56 PM
Official GM Rep
1BDDELX,
It's great to see that you and your dealer were able to track down the part you needed! Hope all goes well during installation, and if you should need anything please let us know. We're happy to help as best as we can!
Best,
Sarah (Assisting Louis)
Chevrolet Customer Service
