fuel pressure regulator
Old Oct 14, 2018 | 5:04 PM
fsnrod's Avatar
Default fuel pressure regulator
My 2000 suburban 6.0 the fuel pressure regulator was just replaced with a Delphi it a make a buzzing noise that coming from the regulator. I pull the vacuum hose it stops This is the second regulator I try ed both the same noise.
Old Oct 14, 2018 | 7:44 PM
maybe check the fuel pressure. are the fuel trims readings high?
Old Oct 14, 2018 | 8:25 PM
geo1's Avatar
Strange,put finger on vacuum line while running,is vacuum fluctuating?
