Fuel pump
Old Aug 28, 2020 | 9:48 AM
Bill Parton's Avatar
Default Fuel pump
I have a 2000 model Tahoe and just put a new fuel pump in it it went about 25-30 miles and quit again no pressure on the fuel rail is there something else that I can look at or did I just get a bad pump
Old Aug 29, 2020 | 8:55 AM
repairman54's Avatar
Possible bad pump. Could be a bad connection at it's connector or the relay for it is bad. I'd check / swap relay first before dropping tank to check connector.
Old Aug 29, 2020 | 10:29 AM
What brand of pump did you install? I have heard of the cheap aftermarket pumps failing pretty quickly. To avoid having to drop the tank again only use Delco or Delphi pumps.
Old Aug 29, 2020 | 11:22 AM
oilcanhenry's Avatar
Yeah, OldChevy. These parts are not made as well as they used to be.
XAQSHNR
K5 Blazer
Mar 29, 2020 5:16 PM
gumby197
Nov 6, 2010 12:55 PM
Khazlett
Jan 19, 2010 1:29 PM
Enstar
13
Jun 22, 2007 10:36 PM
