fuel pump
Old Feb 26, 2014 | 2:03 AM
GusRaby's Avatar
Default fuel pump
ok this may be a stupid question to some here but any help is apperciated.
check my fuel pressure and im not getting any. changed the filter and from the pump to the filter, there is still no pressure.
I can hear my fuel pump cut on, run, and cut off as if it were working right and building pressure. however with my issue, could the pump be bad still, or would my problem likely be from somewhere else?
Old Feb 26, 2014 | 7:51 AM
Desert Gringo's Avatar
could still be a bad pump, if you run it near empty a lot that also puts a lot of stress on the pump it runs hotter . the pickup screen could be dirty, but more than likely a weak pump.
Old Feb 26, 2014 | 10:03 AM
GusRaby's Avatar
ok thanks desert gringo.
i just bought thing thing, so idk how it was drove or the gas levels it was ran at. personally i usally try not to go below a quarter tank myself
Old Feb 26, 2014 | 5:11 PM
Now you are sure there is gas in it?
Old Feb 26, 2014 | 7:46 PM
GusRaby's Avatar
i was, because the guage showed quarter of tank... tried putting more gas in today and got it started... kinda embarrasing. but i checked fuel pressure and its only getting 42 psi.. checked the haynes book and i should be getting 48-55 psi so i do believe my pump is weak, and also gas gauge is messing up... however it is running now. probably will still change the pump but as little as i drive, im going to try and wait till it warms up first!
Old Feb 26, 2014 | 9:42 PM
Don't buy a cheap aftermarket pump. They are usually trouble and not worth it considering the labor involved. Get a Delco or Delphi pump. They are worth the extra money.
Old Feb 26, 2014 | 11:11 PM
Talking
never trust a gauge, haha at least you know it runs now when it has gas
Old Feb 27, 2014 | 9:07 AM
Sergio Lisboa Machado's Avatar
Recently I replaced the fuel pump and also the fuel pressure regulator of my Suburban by a Herko pump, it is working fine. The only intriguing thing is that the fuel pressure drops 3 psi after 5 minutes with the engine stopped, anda it should 0,5 as I have read in Chilton's manual.
Old Feb 27, 2014 | 10:14 AM
GusRaby's Avatar
i'll probably buy a delco pump but have also looked at the OEM delphi
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
