Gas gauge not functioning
Old Aug 30, 2021 | 2:35 PM
Adamsseating's Avatar
Default Gas gauge not functioning
I have a 2000 Suburban. The fuel pump, PCM and gauge cluster have all been replaced. The gas gauge continues to flip-flop between E and F no matter how much gas is in the tank. Any suggestions? It’s been in the shop for 2 weeks now…
Thank You!!!
Old Aug 30, 2021 | 3:06 PM
oilcanhenry's Avatar
Thank You!!!
90 percent of the time is a bad fuel level gauge in the tank. It could be your dash gasoline gauge, but not as likely as the fuel gauge. The reason for this is sub-par manufacturing in Asia.
Old Aug 30, 2021 | 5:10 PM
the possibilities are:
- bad sending unit in the tank
- wiring problem for the sending unit to the module
- a bad gauge stepper motor in the cluster.
Old Aug 30, 2021 | 6:34 PM
Thank you, I’ll follow up with my mechanic!
Old Aug 30, 2021 | 6:35 PM
Thank you, I’ll pass it on to the mechanic!
Josh Raabe
Oct 28, 2013 10:16 PM
BlueStag
Astro
Mar 4, 2012 8:10 PM
dschultz
Dec 24, 2010 11:12 AM
mmanter
Mar 28, 2009 4:02 PM
ironfists44
Nov 11, 2006 4:14 PM
