Which gas to use for 07 Tahoe
Old Sep 18, 2007 | 8:00 PM
  #11
johnebgoode's Avatar
Default RE: Which gas to use for 07 Tahoe
Compression ratio is thedeciding factorfor premium gas. The Tahoe falls into theRegular gascategory comfortably. Premium once in a while, as stated before is fine. Steady diet is uncalled for.
My GTO, which I just sold for the Tahoe, had 11:4 -1 compression and required 93 octane. The Tahoe is not even close to that.
Old Sep 18, 2007 | 9:30 PM
  #12
McGuireV10's Avatar
You can't even make that blanket statement. On trucks like these, sure, but there are plenty of low compression ratio engines that require high octane fuel. The obvious example is forced induction applications, but my Viper runs only 9.6:1 and it still requires 93 octane. In lower compression situations timing is retarded so much that the air-fuel mix experiences quite a bit of compression prior to spark ignition, thus requiring the higher compression tolerances of higher octane fuel.
If you wanna really make your head spin, start looking at the newer variable compression ratio engines that can occasionally peak at 17:1... yet drop as low as 7:1...
Old Sep 19, 2007 | 1:26 PM
  #13
MalibuMaxxSS's Avatar
well learn something every day.....
Old Sep 19, 2007 | 6:28 PM
  #14
Typerod
Jan 7, 2011 11:28 AM
kcw002
Apr 16, 2008 12:08 PM
ldwarwick
Dec 12, 2007 11:42 AM
89K1500
Jan 29, 2007 1:51 PM
