GPS volume problem
Old Mar 14, 2013 | 4:36 PM
Professor's Avatar
Default GPS volume problem
2012 Suburban LTZ
The nav system will not work independently from radio. No radio, no nav.
The nav voice commands do not mute the radio, so I have to run with the nav volume up all the way, which sounds scratchy, and the radio volume set at low.
Is this system messed up or is this the way it works. I seem to remember the nav working better than this, but then again I could be wrong.
Any ideas? Thanks.
Old Mar 14, 2013 | 4:41 PM
kevinkpk's Avatar
If you have the owners manual, check it for the settings
Old Mar 14, 2013 | 4:58 PM
Professor's Avatar
Tried that, thanks. Just got it back from dealer and they talked to tech people at GM and no one had an answer. Their recommendation: Turn the GPS volume all the way up, the radio volume down, and ignore the road noises. Not what you want to hear on a $50K vehicle.
Old Mar 14, 2013 | 5:06 PM
kevinkpk's Avatar
If this is under warrenty, don't take that for the answer MAKE THEM FIX IT!
Old Mar 14, 2013 | 8:01 PM
Professor: Welcome to the forum.
I agree w/ kevinkpk. I had my nav/radio replace because the cooling fan was noisy.
Old Mar 15, 2013 | 7:09 AM
Professor's Avatar
The dealer ordered a new radio. They will install it next week. I just find it odd that this model does not mute the radio when GPS voice is active.
Old Mar 15, 2013 | 2:48 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> Professor,
Please keep us posted of the results of the new radio when it is installed.
Feel free to contact me privately if you have additional questions or concerns.
Louis
GM Customer Service
Old Mar 16, 2013 | 12:40 PM
Professor's Avatar
Louis
GM Customer Service
Thanks. The dealer I go to is really customer oriented. This problem just baffles them, but they are working hard to fix it.
Old Mar 16, 2013 | 6:09 PM
My Nav does turn down the radio volume when she's talking.
Bluetooth also turns down the HVAC fan when a call comes in.
Old Mar 18, 2013 | 7:40 AM
Professor's Avatar
My bluetooth turns things down, too. I wonder if we have the same infotainment system. I should get this replaced this week. I will post new results.
tahoetim
Sep 18, 2008 1:40 PM
Nala
Feb 7, 2008 3:47 PM
4th Burban
Nov 26, 2007 1:10 PM
MCF34
Oct 11, 2007 3:27 PM
cmmotors
Aug 25, 2007 11:42 AM
