Grinding Brake Issues
Old Oct 24, 2019 | 2:57 AM
  #11
oilcanhenry's Avatar
Originally Posted by Irish_alley
if the hub was slightly tweaked a little it might not affect the bearings but an alignment issue with the rotor making it rotate out of square. this would in turn cause it to rub the brake pads once or twice per rotation. its the only other thing that i can think of that might cause it to happen. might not even be your problem but might be worth checking out.
a quote that helps diagnose not so obvious issues
When you have eliminated the impossible, whatever remains, however improbable, must be the truth ~Sherlock Holmes
I think you might be correct, Irish_alley. It does make very good sense to me.
The Sherlock Holmes quote is very similar, but not exactly so, to "Occam’s Razor".
Old Oct 26, 2019 | 2:02 PM
  #12
2010Burb's Avatar
Thanks for the suggestion. After looking into the idea of the hub bearing assembly being bad I actually found a video where a g8 had the same symptoms that I am having. I ordered a new hub bearing and installed it and I am unfortunately still having the problem. Once the hub assembly was off I didnt notice any crunchy sounds though the new one seemed to spin a little more freely.
The only thing I can think of is maybe in the 2 miles or so that I drove with the new pads and rotors before the new hub assembly, the rotor got warp though I'm not sure. I didnt drive it hard since at the time I was trying to break them in. I dont have any more time today but will take the rotor to a shop to get them checked out.
I am at my wits end on this. Any other suggestions? I'm almost at the point of taking it to a shop and letting them figure it out.
endneu913
Aug 7, 2016 12:09 PM
94burbin
Feb 20, 2015 2:59 PM
doktrred
Aug 5, 2013 12:17 PM
chevyguy1523
Jun 27, 2012 6:59 PM
Rickoo
Jul 16, 2011 10:31 AM
